rotrax
And the chances of a leak developing in the rest of it are equally negligible.
Quite right-but by pressing a button for a few seconds you are SURE it is not leaking downstream of the tester.
thanks for the diagrams vics- thanks to all for interesting points to considerUse the BSS chapter 7 as a guide and you wont go far wrong. New version never has been published as far as i know but 2005 version in its entirety at
http://www.boatsafetyscheme.org/media/180428/bss guide 2005 complete web.pdf
Very simple system and a more complex sytem ( PBO Many years ago)
Ah. I forgot that joint. Why not put the tester where the cooker hose joins the copper pipe, then?
I think we now need to start considering how long it takes for a visible air bubble to appear .... and compare this to a pressure-drop test measured with a manometer.(my wife would still probably detect an even smaller leakage!).
Not practical to fit it there.
The place it might go is where the joint is at present but only if its acceptable for it to be outside the gaslocker.
The installation instructions say : "The leak detector shall be fitted after the regulator in the same space as the gas bottle. ......The distance between the detector and the regulator shall be as short as possible."
My point about a few seconds was that a VERY tiny leek would take some time to form a bubble large enough to be obvious. (You may argue that then it is so small it does not matter). Of course a substantial leak - or tap turned on - will cause an obvious stream of bubbles.
Manometer: Yes, it is essential to drop the down-stream pressure a little below the regulator pressure (after turning off the bottle) otherwise the residual up-stream pressure will maintain the pressure for some time even if there is a leak. A common mistake indeed.
Frankly, I think people are generally irrationally concerned about LPG safety on boats. The incidence of accidents is incredibly low, and if you look at the circumstances of most of the accidents, sheer carelessness is often the cause. As with many aspects of our society, this has become a "jobsworth" issue with "health and safety" being used as a justification for excessive regulation.
vyv-thats why i moved the gas cylinder to sit by tiller strapped to pushpit so no worries about leaks into cockpit/bilge-the water drains are looped so gas couldnt get out that way-not too sure where leak detector etc would go in our situationInteresting that every Sadler 32 and 34 ever built, unless modified subsequently, do not have a gas drain overboard. Gas leaks are supposed to drain from the cockpit through the water drains but the elbows on these are attached to the forward-sloping transom, forming a reservoir for water. It is therefore impossible for gas to drain away. How many of these boats have suffered gas explosions? I have never heard of one.
I have a bubble tester in my gas locker. After a long period of being shut down, say 4/6 weeks I turned on the gas and it bubbled for about 2 seconds.
4/5 hours later i tested it again and all was okay.
I am going to check it out as I believe there is no tolerance allowed on LPG.
That's a decision made then...Read the instructions for the leak detector and I think you will find that they suggest holding the button on the detector down for 1 minute
Can you turn the gas on please darling.
OK, just a minute...
It's not coming on.
I know, just wait a minute.
I'm standing here with my third lit match, what's the problem?
I'm checking something.
Do you want a cup of tea or not?
Just 30 seconds.
Make your own ****ing tea!
On our boat I religously ask First Mate to hit the gas solenoid switch, as soon as the main batteries are on. When she calls " on " I turn the gas on at the bottle and depress the tester button and watch closely. No bubbles I call " OK " and she switches it off. Never seen a bubble yet unless the cooker is on, or on the occaision I cracked a joint at my " belt and braces "tap.
Simples.........................
Do you have a gas alarm permanently powered?
I dont have a gas alarm period.
I use primary safety.
Gas alarm is secondary.
The gas is turned off at the cylinder when we leave the boat.
The bubble leak tester is used as soon as we get back to the boat and the batteries switched on-the electric solenoid will not work untill then. As I stated earlier, this tests the lines right up to the appliance. I am happy-no bubbles= no leaks. Our cooker is a high quality American one more often used in the posh motorhomes from that country.
I was crew on a boat with a gas alarm.
It kept going off when there were no leaks and was disconnected by the skipper.
As another poster said, gas accidents are very rare on boats compared to the number of boats fitted with gas.
