Graham_Wright
Don't compressed air tools operate at pressures about 150-200 times higher than a gas solenoid?
………only if they operate at 0.8 p.s.i!
My supply runs at around 7 bar (which is I guess you meant!).
Typical gas regulators on boats operate at around 28mbar, which is therefore the pressure to which the gas solenoid is subjected. If your air tools operate at 7bar, that's actually 250 times higher than the pressure the gas solenoid is under. The point I was making is that your experience of leaks bears no relation to the conditions under which a gas solenoid operates.
Didn't know that. It always seems scary when I crack a cylinder valve.
Now - about the bubble detector location. Anyone?
The only sensible place to put a bubble detector is in the gas locker. If you can't do that, sell it.
Indeed you could.In my case, for historical reasons, there is a join in the copper pipe just outside the locker. I could fit one there without even increasing the number of joints.
I know they are usually located in the gas locker but why?
Indeed you could.
One of the (many) reasons I have delayed the installation of my new gas pipe is because I can't decide how to terminate it at the locker end. At present it has a flange join with the rubber hose the other side; ideally I'd like to eliminate the join outside the locker.
The theory's fairly straightforward. The bubble tester only shows leaks downstream. If it's in the gas locker, any upstream leak will drain away safely. If it's outside the gas locker, any upstream leak could end up in the bilge.
I understand that but would a tester outside the locker be better than no tester or is it just unacceptable to fit it outside the locker.
I understand that there should be no joints outside the locker until the cooker isolating cockI understand that but would a tester outside the locker be better than no tester or is it just unacceptable to fit it outside the locker.
Yes, I have a bulkhead fitting at the moment. The pipe I'm using is plastic covered, so I will need to go up a size or two (I will have to measure the OD when I next visit), but that is a good idea, thank you.Get a bulk head fitting.... but drill the "land" out of the centre of the union ...
A poster asked why the bubble leak tester should be in the gas locker. They need to be as close to the scource of gas as possible so they test the longest possible run of pipe to the appliance, and the appliance itself.
IMHO, they are one of the best bits of safety kit going in regard to gas on boats.
But I have two choices : No bubble tester or a one immediately outside the locker.
The chances of a leak developing in the couple of inches of copper pipe between the locker and the leak detector are negligible.
And the chances of a leak developing in the rest of it are equally negligible.
I agree. The only likely places for leaks are joints, and if you put a bubble tester outside the locker you have added two joints in unventilated places. On my boat that would double the risk.
But as I said earlier there is already a joint ( there is no objection to properly made compression joints) where i would might put the tester......... Which id fitted would check the most likely palce for a leak which is the flexible hose to the cooker
