snooks
Splutter, splutter, without anchor threads how would this forum survive?
Dunno, we might have to talk about sailing or summut
And from that we can potentially draw lots of different conclusions.
Oyster have got a cheap deal with the CQR distributor.
Oyster know nothing about anchors.
Oyster owners don't get involved with anchor selection.
Oyster owners dont anchor very much.
Oyster have conducted extensive research into anchors and concluded that the CQR is the best one to securely hold a very expensive boat.
Almost all Oyster owners have conducted their own research and have chosen a CQR.
Being a skeptical sort I am more inclined to believe the first two than the last two.![]()
This one was done by a very respected authority on the subject, quite independently of any manufacturer interest, in as scientific a manner as can be possible
Having read the article, I couldn't make hog nor mutton of the script. The figures are for anchors of different weights, so it seems to be impossible to compare like with like. Also, as the photo shows a Danforth at the beginning, and then they are never mentioned again or tested, what the b'jesus are they talking about.
Meanwhile, those of us with a Spade just sit here feeling unbearably smug!
Lightly used? is there not a danger of it getting wet out there if it ever rains?
One finds one only takes photographs of one's anchors when they are fresh out of the purveyor's bubble wrap.
I assumed that he used the Danforth to restrain his test rig. This therefore proves that the Danforth is the best anchor if you don't want it (test rig or boat) to move.
My boat has a Danforth.
This article on the test by Professor John Knox, himself an experienced sailor is seemingly unbiased, attempts with a few common anchor types, to show their performance in just two sea beds. One of course wet sand the other of wet sandy mud.
He makes the point that to have even more conclusive tests the man hours would have been impracticle for him and his assitant. He also points out that in very different sea beds, results would have been different. The ability to initially penetrate the sea bed and then the ability of anchors to stay held fast to the sea bed rather than dragging or breaking out, being the most significant variables between anchors.
Using the 6kg Spade as the 'bench mark' after 9 tests, about which others are defined gained a score of 120kgf.
He concludes that the Ultimate Holding Force UHC = the maximum Capacity the anchor will hold without moving in the seabed, of the anchors he tested was as follows.
Best first.
Rocna 15kg = 480kgf
Spade 15kg = 420kgf
Manson Supreme 25kg = 225kgf
Delta 35lb = 186kgf
CQR 45lb = 175kgf
Spade 6kg = 120kgf
Rocna 5kg = 85kgf
Bruce 15kg = 80kgf
Delta 15lb = 76kgf
CQR 15lb(dug in by hand) = 68kgf
Bruce(Marathon)15kg = 50kgf
CQR15lb = 44lb
Bruce(Atlantic) = 43kgf
Bruce 5kg = 35kgf
Delta 9lb = 34kgf
Why he failed to test the Fortress and Danforth I question! ??
The efficiency= UHC/Weight, put the Spade just first, Rocna a close second, with the Manson third. The rest were very much behind the leaders Delta,CQR and Bruce in that order.
An interesting test I've done on the boat to demonstrate the depth and holding power of concave and convex shaped anchors..............
Take 2 similar size/shape desert spoons.
Bend the spoon of one back on its normal position by about 70 degrees, the other forward of its normal position by a similar amount.
You have two miniature anchors. When dragging the two into a bowl of sand or sugar see which one digs in deep and seems to hold best and which one tends to drag and break out.
PM me and I'll post a couple from my local Oxfam shop!As I can't afford to waste two spoons can u let us know the result?
Snooks will undoubtedly confirm this to us, being an honest fellow.
