Elessar
I find it a poor business, the few times I have tried it.
Thin rope is affected by the breeze and if it is held up on the merest arc of a round buoy, it is liable to slip off it's shoulder and you end up going around for another shot. If you do score a hit it can tarry on the surface and the retreating boat pulls it away and you go around again, this can happen even if you throw yourself to the deck and attempt to marry to two ends or cross them under the bow, around you go again. Even when you think you have it and turn your back for a moment the line can slacken and throw it's collar and away you go, yet again
Heavy rope is less affected by the wind but more likely to ride back over the buoy. Chain would probably be better but best not mention that.
I can't imagine why anyone would waste time with this method if the mooring has a ring on top
I know all this because I did it last year with my club mooring. They have no ring of any sort and are perfectly spherical inflatable buoys which suspend the heavy chain with maybe a festering metre hanging vertically down for you to retrieve for you pick up gear. Horrid, slimy and wet but my own fault for being too idle to sort it out in advance in a dinghy. Can't say I did any damage to the mooring though.
The idea of lying to a bight in this way is bonkers, even without Jumbleduck's underwater razors
if you haven’t taken the time to learn how to lassoo, how do you safely tie up in marinas?
I can reliably lassoo a cleat that is 10 ft away and usually more. Even poor attempts at marina entry can be rescued this way. Good attempts still benefit from lassoing as it allows the boat to be safely (albeit temporarily) secured before stepping off the boat.
As for ”wasting time” on mooring buoys if it has a ring, how do you reach a ring that is 6ft below the gunwhale?
