charles_reed
Just beaten to it. Good point about output curve, that's why I stuck with a 110A replacement. It had much better output at lower rpm and actually gave a much larger boost than you'd think when going from 80A to 110A (at normal cruising speed). Still theoretical of course as I haven't fitted it yet. One other problem with changing the alternator is that you will probably affect the tachometer. I think that you'll find that the alternator sends a pulse to the tachometer each revolution. Unfortunately, the engine turns at a different speed and the rev. counter is setup to allow for this. Not a big problem for me as I downloaded setup instructions and did some calcs. to get the corect adjustment factor.
You need engine pulley size, alternator pulley size and some technical info about the alternator. Of course you could be lucky and find that nothing has changed.
If no change to alternator or drive pulleys, the change in alternator should not affect the tachometer.
The point about output curves is very valid - you need to choose an alternator which is also fitted to a slow-revving diesel and not a fast revving car.
I have no doubt that fitting a smart controller works alternators much harder - usually only the diode bridge burns and fitting a new one is cheap and easy, apart from the hassle of taking the unit out. Because it happens at the most inconvenient times I carry a replacement now. However the 80 amp Hitachi on the 3YM20 literally melted - the disadvantage of an alternator with no forced cooling.
As I suspect it is exactly the same unit on your engine I'd definitely look at changing it - to one used in a slow-revving diesel (such as the Transit or cast iron Iveco) and with an integral cooling fan.
"Marine" alternators are not worth the extra you are charged for them - the 90 amp replacement for the Hitachi cost me only €79, brand new, and the Magnetti Marelli was £124.
