samuel
I recently purchased a laptop ( Dell inspiration 1100 ) & as I am off to Med ( See Med which way ) I thought I ought to give some consideration to contact with family at home.
One of the mags recently carried an article on a device for E-mailing which connects to a laptop.
Having seen lots of articles about laptop use on board i thought it could be a viable way of contact.
When I rang Dell to order a cable to connect to 12 volt supply they said they could not help. I was absolutely amazed to find that even though a laptop is for mobile use you cannot connect to a cars 12 volt supply for power ( So likewise a boats supply )
We do not intend to park up in marinas all the time & infact the boat I have ordered does not have shore power capability.
So here is the question !! How does one run a laptop for continuous use or for more than a couple of hours if you cannot charge it off the ship's supply?
Suggestions so far have included an inverter for going from 12V to 240 V & then using the standard mains charger to power the computer. This seems very inefficient & is it possible anyway? If it where then it must use stacks of current.
It seems from chats in the yacht club that other makes of computer such as Sony may have the same problem.
The DEll battery seems to be 15V but the charger is labled 20V.
Would a 15V battery run off a ship's 12 V supply direct & where would one get a cable from?
Any Ideas ?
<hr width=100% size=1>Justisla
Any Ideas ?
