mikesyam
Hi All
Got a problem which Hopefully someone can help with, got a KVH G6 Hst Sat Dome fitted feeding a Sky box with a genuine card, around a couple of months ago it started loosing the signal on some channels with "no signal being received" showing on the tv along with the Sat dome whirring its head off trying to find a signal, should add thats with the boat tied up not while moving, have done 3 master resets on the Sky box as well but its just the same.
Heres the odd bit realised the only channels which I loose are the free ones like all ITV and all the BBC channels every Sky channel which I subscribe to works fine,
so this is what happens,
Watching Sky1 and flick down to Channel 5, after approx 10 secs you loose the pic and get no signal being received along with the Dome whirring away searching, you can leave it for hours and still no channel 5 yet if you flick back to Sky1 within 10 secs the pics back perfect, basically pick any ITV/BBCChannel 5 prog including ITV +1 ITV2/3 you loose the signal after 10 secs, flick back to Sky and its perfect.
Hope that explains ok and thanks for all advice. Mike
