KajLehtinen
Hi!
For me new boat, Kohler genset - worked fine during seatrial. Now it starts and after about 15 seconds it sounds as it connects the load then it the genset stops, after about 10 seconds it restarts to and same procedure again and then once more to finally give up with a OC code.
I can see from the outside that coolant water is coming and some light smoke, and engine runs fine during the 10-15 seconds it takes before the relay click is heard and the engine stops.
Any ideas? Someone mentioned bad starter battery, i'e that it doesnt have enough power to switch on the load and dies due to that?
/Kaj
/Kaj
