Ric
If you are using a rolling hitch then probably you are only using a single-line snubber, lead either over the main bow roller, or asymmetrically through fairlead to cleat. Both are sub-optimal, as they will not prevent the boat snaking around at anchor.
The advantage of a good V-snubber with a hook is that it can be lead symmetrically through both fairleads to both cleats - and this significantly damps down snaking at anchor.
Admittedly, you could rig a V-bridle with a rolling hitch - but I doubt many of you do!
