Greenheart
I butted into a thread last November to ask what would be the best way to prevent the very taut vang rubbing grooves in the deck at the front of my dinghy's cockpit.
Comments were made, regarding the fact that technically, perhaps the vang shouldn't be so taut when broad-reaching...
...but since I singlehand, there's every chance that I won't remember to slacken it in time every time, so I wanted something to toughen-up the rounded deck-edge. Products were suggested, including flexible stainless steel strips, and a narrow stainless strake...
...and I expect either would have been fine, but they were a bit blooming small for the application, so I'd have needed four or more likely six of each, with the cost running well north of £30...
...until I saw a KEVLAR equivalent...kevlar wear patches, at Force 4...I saw that the Kevlar patches could be cut to size, and calculated that one pack at under £20 would cover all the vulnerable area.
Unfortunately Force 4 also sells CARBON wear patches, and below is the picture of them in use, almost exactly as I had envisaged...I'm not quite sure if the carbon patches can be so easily cut as the Kevlar, but I definitely confused the products...
...and having fitted the kevlar strip, I thought I'd give the newly-armoured deck-curve a bit of vang-style abuse to test it. That lasted less than five seconds...photo below...the grey area in the middle is my GRP showing...the rubbing rope went straight through the kevlar, and the new paint, and began to bite into the deck.
So, I've learned a £20 lesson...carbon may be up to the job of resisting rope-wear, but kevlar definitely isn't.
Which leads me to wonder, what is the kind of wear which the product I bought, was meant for?
I'll get the stainless strakes. Or look for some wide-diameter scrap stainless tubing and segment it with the angle grinder.
