AntarcticPilot
+1, for at least two reasons!When the sailmaker was measuring up for my new mainsail he gave me a little demonstration. Put a slider in the track pull it straight back and slide it up and down. Then pull it to one side and see how much more difficult it is to slide up and down.
Moral: getting the boat head to wind matters!
First of all, it reduces friction between the sliders and the track; you can minimize this and the spray I use is about as good as you can get - it is molybdenum sulphide in a PTFE carrier; it provides a slippery coating on what it is applied to. I hate to think what it would cost to buy; I get time-expired cans from my wife's work! The stuff is designed for use in demanding engineering situations, where both high bearing pressures and heat are likely.
Second, on my rig and many others, raising or lowering the sail when it is not directly behind the mast will result in battens catching on the cross-trees or on the lower shrouds. And if you're not head to wind, slackening the main halliard will result in the sail twisting so the battens catch on the rigging.
Finally, why not? If I'm dropping sail, the engine will be running, so I can easily arrange to motor slowly into the wind. I have a tiller-pilot that makes that easy. Being head to wind makes it much easier to work on deck, so I can flake the sail down on the boom in reasonable conditions, and bundle it up as best as may be in unreasonable ones. I couldn't do either if the sail was drawing.
