dunedin
Depleted uranium is highly radioactive and anyway, where did they get it from?
I think Club Med was supported by the French government / shipyards - so presumably had access to the huge French nuclear industry
I was under the impression it was depleted uranium which if i can recall my school physics becomes lead when it has finished reacting. I would imagine it was just lead but more pure and dense. I would be interested in someone with a genuine understanding of the science's input.
The slight softness of lead also helps, as Stork says, if you hit a rock: it has considerable shock-absorbing properties and reduces the chance of hull damage at the aft end of the keel root - the usual consequence of hitting a rock at some speed with an iron keel.Perhaps you should tell the Swedes then. Antimony is added to the lead to make it sufficiently stiff for the keel,with some residual softness, great for those Baltic rocks. Even Bavaria offer lead keels on some if not all models.
I was under the impression that most supposedly lead deep fin keels are actually iron keels with a hollow bulb that is filled with lead - it's more a performance thing than durability. Filling the bulb with lead allows you to get the balast weight lower and to reduce drag since a given weight occupies less volume.
If you'd actually been paying attention you would also recall that U 238 ( the major, and non fissile, constituent of natural uranium ) has half life of 4.5 billion years so you are in for a long wait for your uranium keel to turn into lead.
Clearly wklein's memory of school physics has a somewhat shorter half-life.
Actually even if you wait 4.5 billion years your Uranium keel wouldn't turn into lead.
"Depleted uranium is highly radioactive"
No, Depleted uranium is slightly radioactive.
Both isotopes that make up natural uranium U235 ( the fissile one) and U238 the main one at nearly 99.3% are only weakly radioactive by virtue of their very long half lives
Both decay by alpha particle emission.
Alpha emitters are easily shielded. A piece of paper will stop alpha particles, but they are potentially very damaging if ingested.
Yes I do know what a "half life" is.
If you want a really dense material for your keel perhaps you should consider osmium. At 22580 kg m-3 I dont think you'll beat it
"how about a gold keel"
It was the basis for a thriller - how to smuggle gold undetected.
How about attaching a blackhole to the bottom of your boat? Or a piece of neutron star?
