Bosun Higgs
N/A
Got my doubts for several reasons. First is that a prop works by "sucking" water in at the front and expelling it at the rear, so you are just as likely to get floating rubbish sucked round you prop with the wire as without it.
Second is that you could get rubbish round the wire itself and also round the prop - so the rotation of the prop puts a huge load on the centre of the wire which ( basic trig) is multiplied even more where the wire fastens to keel and skeg. Depending on how strong / well fastened you could even pull the skeg off - a pal of mine pulled his gearbox off the engine with a mooring chain rouind the prop..
Thirdly you have even more underwater protuberances for rubbish to catch on - the wire itself.
Fourthly - are you sure you will never run aground, partially dry out etc. On uneven ground. Load on center of the wire, multiplied load on the skeg and keel fixings.....
