Rappey
Westerly centaur. The bilge keels have hollows in the casting filled with expanding foam.. This has been replaced , epoxy filled over the top of the foam giving a large flat surface to bond to the hull. The keel has then been coated with a few layers of epoxy paint
This is where it gets interesting..
Sikaflex has been used for the job and the person whos boat it is took advice from sika technical which sealant/adhesive to use and how to use it. Apparently they have a lot of information on how to bond keels to hulls.
A 5mm gap is to be left between the keel and the boat hull which is totally filled with sika. Once cured the keel bolts can be torqued up to the required amount which was achieved.. while maintaing the 5mm gap. Ive never heard of anything like that before and think the keels should be touching the grp.. What do others think or know?
Im helping a friend on a boat next to this centaur.. We have been doing some serious work filling/fairing with jotun mega filler (2 part epoxy) and then 4 coats of jotun epoxy on the hull below the waterline.
The centaurs keel was sealed/bonded about a month ago. The sealant went of like sika does..
But now the sika is going soft.. Its like its reverting back to how it came out of the tube?
A few smears of sika were on the surface of the keel, probably from wiping it off ones fingers ..These smears are now very sticky and its like its not set, but it had previously..
Has anyone come across sealant reverting back to sticky before?
The centaur owner has suggested the dust from my friends boat alongside in the yard from sanding the jotun mega filler may have affected it or possibly the fumes from the epoxy paint has had an effect? We used ct1 to go around the keel/hull joint on my friends boat and its perfect..
What is also a little strange is that only the sika on the outboard side of the keel facing my friends boat has gone sticky, the inside is still solid.
