pat_detente
Active Member
We have a Moody 33 Mk1 fin keel. The survey suggested that we check the keel bolts but I am unsure how to do this. The tops of the bolts and nuts are glassed over. Can anyone tell me what I should be doing? After removing the GRP do I :
a) check the nuts are tight;
b) remove the nuts to check the threads;
c) remove the nuts and check the studs are tight;
d) remove the nuts and try to remove the studs (not all at the same time, natch!).
If I am to remove the studs, what am I looking for? Corrosion, obviously, but what about cracks, evidence of minute crevice corrosion?
Any advice will be gratefully received!!
