Momac
Your right!! the only bit of an oil leak is off the intetcoolers they both look like they weep a bit , I read. Something on this forum a while ago but I came to the concision that they all do it a bit and it was nothing to worry about ? It doest actually drip much oil on floor as such more of just a weep, this is on both sides ,the intetcoolers are very hard to get to on this boat
If the oil escape is very small - a few spots on the floor its not an issue. The intercooler has a small condensate drain hole. It is oil passing by the turbo when the engines are slow running and not up to temperature. Any oil from the intercooler should stop after the engines have had a good blast up to temperature. I had one engine where the oil would not clear up and the amount of oil leaking though not huge and not enough to make a change on the dipstick level, became a more significant patch on the floor rather than a few spots. I had the turbo removed and repaired which has cured the fault. I caught it early and the cost was not cheap but a lot less than a new turbo.
Wipe up the oil and keep an eye on it. Also check the air filter boxes for any oil and if the air filters are dirty fit replacements. By the way the air filters are relatively cheap if you but from a car spares shop.
https://www.gsfcarparts.com/122vo0010
Use discount code GSF30
Oil in the intercooler may inhibit engine power slightly in that the intercooler is not cooling the charge air quite as efficiently as it should. I am not sure if that could explain could explain or contribute your revs and fuel issue.
Initially just clear up the oil and monitor. It may be come to nothing.
A friend has a F36 and I understand the issue with engine access. I don't think its much different on any other similar mid engined shaft drive boat of about the same size. I have a F33 which is on outdrives so the engine access is far easier.
