aerobat
Hello gents !
if i understand it correctly the supercharger envolope on the kad 44/300 is a bit different than the mechanical kad32/43 .
Not fixed cut in at 1500 and cutout at ~2800 but controlled by ECU depending on conditions .
My question :
the manual says the supercharger range is between 1000-2800rpm .
Is this the envelope where ECU can decide to call for the supercharger depending ln load etc or does it mean that the engine spins the supercharger all the time at anything above 1000rpm,s , so you virtually will do anything below full planing speeds with the charger engaged ?
I know the '44 will spin the charger when engine is cold or will engage it immediately when you "gun the engine" , i ask for a warmed up engine and a steady hull speed trolling on an inland channel
Thank you very much !
My question :
