petem
I believe I have an issue where the boat is intermittently staying in gear instead of going into neutral as selected. I'll try and recreate the issue this morning but am I correct in thinking that a throttle recalibration can sometimes fix it? Note that I was advised at the service a couple of weeks ago that one of cables was becoming stiff and should be changed when the bellows are next changed otherwise it could damage the actuator. In the meantime the cable re-greased.
If the recalibration doesn't work then the issue is either:
a) the cable
b) the throttle potentiometer
c) the actuator
d) clutch cones
a) the cable
c) the actuator
d) clutch cones
