malc60
I have sunseeker with 2 KAD44,s both engines running at 95-100 degs, tried the obvious, its in the med, is there a chance the intakes could be slightly blocked on the legs? PLEEEESE
I would check the readings with an IR gun before you start. Corrosion can increase the readings. Iearned this the hard way.
Emmery paper / WD 40 —- back reading 86 .
Using emery paper isn't great but tempting if that's all you have. Contact cleaner spray plus a contact cleaner pen will do a better job.
This is good advice .
I had 96 with a kad300 ,
IR gun said 86 - hmm
Turned out ver d Gris on the guage spades under the dash .
Corrosion of any contacts - sender / harness / gauge spades = inc resistance- and it reads high
