Raff riv
I certainly hope so, would be my only Xmas wish!
Porto, that's not my understanding. On another thread Volvopaul advised that if the Seafire system was shutting the engine down then the temporary workaround is to pull the the purple wire out of the stop solenoid.
Pete to quote Dennis “ read the posts ...... “
I never mentioned your “ seafire “ .You introduced it and the Op confirmed / answered your query.
What’s “ seafire “ got to do with it ? It did not come from me .Thats your baby Pete with this thread .You own that .
As it’s turns out a loose bat connect ( does not matter which polarity) I conclude I was correct with my assertion of intermittent LOSS of power to the stop solinoid. They normally need power !! - simples !!
The only slip up was I assumed the op had checked all the connections which I reiterated in my final post if you care to re-read that .
Let’s face it bat connects are pretty fundamental.I check mine routinely in every thing that has batts btw .
Was driving a Testarossa in a Waitrose car park U.K.about 20 years ago and went over a speed bump , the damm thing stalled blocking the exit.
Dead .
AA man just reconnected the bat as one lead although looked like was on had bumped up the tapered post and lost sufficient contact to power the 5.0 L 12 cylinders Bosch fuel injection system = engine dies .
School of hard knocks Pete
I learnt about batts pdq.
The Volvo part will be daft £££
Some on here I beleive have had success using car Ecu repairers. Coastal rides are worth a try for a pre loved one
Thanks guys, spoke to a tech today and said they will try updating the software and see how it goes, otherwise a new one is 4K Aud!!! Regardless now it’s on the port engine I won’t lose my power steering I may leave it till after the Xmas break
