BruceK
I recently changed the piston cooling bypass valve on the left below 1; parts 8 7 5 4 and 3 but not 2. All new parts and it is leaking vast amounts of oil past the o-ring (7) and plate (8) while on idle. (steady fast drip) I pulled it all apart in case the o-ring was misaligned in it's seating and destroyed. It wasn't and on inspection it was in good order. I put it all back together carefully while in-situ on the engine block and it leaks even worse now. Bother! Compared all parts to those that were removed including silicon o-rings and exactly the same. Relooked for any damage anywhere and nothing. Still leaks. OK this has to be something extraordinarily simple but I will be damned if I can figure out what it is.
