Kad 300 alternator belt tension
jon and michie
28 Dec 2014
Hi when I was last on my boat I noticed that there was slack in the alternator belt.
Basically when I pressed my finger on the belt it deflected by about 20mm - is this too much??
When I have worked on my cars alternator I have never had the belt this slack
Many thanks in advance
Jon
Might be an idea to check the width of the belt vs a new one.
If substantially narrower, then clean up the pulleys with some emery paper and fit a new one.
Thank you for the replies - the v belt itself looks like there is still life in it and I am getting a replacement at hand.
Before I left the boat I sprayed the bolts with wd40 and will do so again to make it easier on the bolts.
Thanks aga
Jon
