sharpness
From previous insurance posts / debates, another company whose policy wording came out positive who i have insured with for the last 2 seasons is yyachtinsurance .
providing that the corrosion was neither known nor ought to have been known (because it was obvious or would be discovered by a reasonable inspection) ?
Hope you lot check your seacocks on at least an annual basis and don't just rely on insurance cover
Lions Den had a faulty seacock last February which came to light in Berthon @ 04.00 in the morning with the bilge pump kicking in every 30 minutes - Transpires to be a faulty casting but I would have been covered if the worse case scenario happened.
I check all seacocks every 3 months and operate them to ensure they are not seized.
I know one chap who never touches his seacocks just in case he breaks them - He is not one of us lot btw
Terry
I wanted to wake up this very interesting thread with an update from GJW with whom I insure my boat. I asked them to clarify the situation with regard to their cover if a seacock eroded and the boat sank.
They said not to worry it would be covered but I asked them to put that in writing which they did by email. Here is what they said on the matter
[GJW]So far as our position is concerned in the event that a part corroded and failed causing damage to any other part or parts providing that the corrosion was neither known nor ought to have been known (because it was obvious or would be discovered by a reasonable inspection) we would consider ourselves on risk for the damage to the other insured parts. That has been our position for upwards of 30 years (which is as far back as we have been able to trace) and we would expect that to be the reasoning of the Financial Ombudsman Service. This may well be the reason we have no recorded complaint in respect of this or any connected issue.
Legal advice we have received in the past is clear that this is the correct and only construction that can be placed on this wording.
We trust you find this explanation acceptable and certainly so far as we are concerned we have no objection to you publishing this letter to correct the errors that are apparently being propagated.[/GJW]
They said more than this in the email but it was mostly a discussion on what erosion is and their comments on what is covered in the HKJ and Pantaenius policies. If any one is interested in what GJW say about HKJ and Pantaenius let me know and I'll post that too.
So GJW customers are you happy with that?
JFM - does this pass the test?
Just wondered how you check your seacocks every 3 months, what do you do?
For me I check mine annually when the boat is out and that involves scraping the antifouling off the outside fittings to show any signs of pinking and check the fittings don't move etc. Every time I visit the boat I check my seacocks by operating them and check for any signs of leaks/corrosion. I only have two seascocks so it is quite straight forward. I also fitted a customised alarm, so if the bilge pump comes on I get a text message.
But I do wonder what the insurers seems reasonable in terms of maintenance of these things. I also keep a log of all maintenance which may help with insurers, but that wasn't the reason, it was so I could keep track of what has been done and when etc.
Anybody looked at craftinsure, they seem to have been pretty good so far, but would like to hear of any similar problems.
Yup - I would change the manufacturer installed ones at 5 years and thereafter at say 6 years (as I would know the quality and bronze nature of the replacements). Changed them all on my brother's boat couple of years ago. On my current boat I found a hosetail that was too pink for my liking. It was an isolated case, they are generally dzr/bronze, but you cannot eliminate a mix up between bronze/brass at the distant end of the supply chain. So I changed it immediately for one I Knew was bronze. You can't be too careful imho and having insurance isn't a reason to skimp - I don't want the boat to sink, insured or not! Also the boat SMS-es both my mobiles if there's water in bilgeDoes anyone on here routinely change there seacocks on a 5 or 10 year basis inc adjacent waste pipes etc as part off there maintenance regime
No it doesn't "pass the test". What a crummy bunch GJW are. Let's get a few facts straight:I wanted to wake up this very interesting thread with an update from GJW with whom I insure my boat. I asked them to clarify the situation with regard to their cover if a seacock eroded and the boat sank.
Yup - I would change the manufacturer installed ones at 5 years and thereafter at say 6 years (as I would know the quality and bronze nature of the replacements). Changed them all on my brother's boat couple of years ago. On my current boat I found a hosetail that was too pink for my liking. It was an isolated case, they are generally dzr/bronze, but you cannot eliminate a mix up between bronze/brass at the distant end of the supply chain. So I changed it immediately for one I Knew was bronze. You can't be too careful imho and having insurance isn't a reason to skimp - I don't want the boat to sink, insured or not! Also the boat SMS-es both my mobiles if there's water in bilge![]()
It's entirely up to you, but you might want to reflect on how much you may in law claim you have relied on GJW's email to PEJ. Sure, you'd have a decent leg to stand on, but you'd be wobblier than the HKJ or Pants policyholder. I'd say get yourself a direct contractual right to a payout, which is what an insurance policy is meant to be.Thanks PEJ, I am with GJW and was going to ask the same question when it is time for renewal. I find their response more reassuring.
1. GJW's policy wording is
This Policy does not cover physical loss of or damage:
1. to the Vessel caused by:-
(iv) corrosion, rot, rust.....
(v) electrolysis;
As a matter of plain English, that wording means you are not covered if the proximate cause of boat sinking is seacock corrosion/electrolysis. You can all see that as well as I can. This legal advice GJW say they have received in the past will not have said anything different - I invite them to post it here. I do contract stuff at a much higher level than this (I mean a higher level than a law firm advising a small boat insurer) and I'm absolutely correct on the meaning of those policy words, whatever GJW say. Anyone with a basic grasp of English can see that. Also HKJ's lawyers agree with me, and HKJ changed their policy this year - good on 'em for that
2. The same wording was in the policies held by Seahope and the scuttlebutt poster (who wants to be nameless). Their insurers/claims handlers (BIG names in the UK market, but not GJW) refused to pay out, based PRECISELY on those words. This is 100% contrary to what GJW say above
3. In Seahope's case we won by a clever bit of thinking early in proceedings, before any ombudsman intervention. In the scuttlebutt case we appealed to both levels within the ombudsman service and lost - I mean the ombudsman junior + senior levels both specifically and categorically decided (among other things) that these words excluded the boat owner's claim. So do not attach any credence whatsoever to GJW's predictions of what the FOS would say. We won the scuttlebutt case (with 100% payout + interest; insurers got a well deserved bloody nose lesson but it was hard work and my knuckles got pink) just as I was starting legal proceedings based on a clever bit of procedural footwork, but we did not win on the interpretation of those words in the policy, nor could we, nor would I have wasted my breath asking a high court judge to rule that those words allowed the claim to succeed. So, I repeat, GJW are wrong about the FOS
Now, if GJW will pay out on the seacock corrosion scenario then I applaud them for that. That's obviously a good thing. But they're paying DESPITE the policy words not BECAUSE of them. I much prefer to have my insurance and my risk transfer based on CONTRACT not GOODWILL, so I'd still say imho do not buy GJW policy because there are better offerings from others. You PEJ are in a strong position because you have an email from GJW to you on this very point, and that gives you a strong position. Others merely reading this are not in anywhere a near as strong a position
As regard GJW's "correct the errors that are apparently being propagated", that is just incorrect. There are no errors here on my part; GJW are very firmly in error in saying to people that their wording (as distinct from their practice/goodwill/concession) provides payout in the seacock scenario. That is very misleading advice and if someone were to rely on it but buy say Seahope's policy (which has substantially the same wording as GJW), that would result in a bad outcome in the seacock scenario
GJW, if you really care about this just change your policy words. I'll happily read a redraft and sing your praises as I now do HKJ's; I have zero axe to grind other than wanting the folks on here to get good contractual cover for the main risks a boater faces (even at higher premium, but if as you say your practice is to pay out in these circs then you wont need to raise your premium). Others, be very careful before attaching any credence to what GJW write above. GJW's customers shouldn't imho be "happy" (to use PEJ's word), and this doesn't "pass the test".
(Of course we have the classic problem here that GJW are a big name in boat insurance whereas I'm an anonymous internet poster, so people in general are going be inclined to believe the "brand name" GJW rather than the random forum poster guy. That's a pity and I cant help it; I don't want to get into a badassery competition with GJW employees about who knows more/is right on this stuff
My point is that insurance companies are all lovely when selling you the policy or paying a small claim, but when you make a life-changing claim they are sometimes not so friendly and what you need to get paid is a CONTRACT that clearly transfers your typical boating risks to the insurer.
Following my conversation with GJW on this very clause my stance at the end didn't change despite their assurances that they are nice people and market leaders. As far as I was concerned GJW can and possibly always stand by their policy wording and if they don't want to pay they won't. As JFM says above, a goodwill payment is very honourable but they are an insurance company and they play by their rules not ours.
I'm happy that I have changed to another insurer even after 10+ years but I would revert back to them if their policy wording changed for the better and they were competitive.
