chal
My newly-acquired 1979 Westerly has one of these and it doesn't work. It is probably an original fitting. That is quite old, I know, but the boat hasn't been used much over the years and the heater seems to be in pretty good condition. Even the piezo spark device still works! I've taken the cover off and it all looks fine. The problem is that no gas is reaching the burner. There is definitely gas reaching the heater - I have checked by removing the pipe from the isolating tap just below the heater. There is also water going through the heater. The slider control at the bottom has a pilot position and the usual press-and-hold-to-light routine, but when pressed, there is no gas to ignite. Can anyone suggest anything? I don't know if there is any kind of gas shut-off mechanism incorporated into the burner as I wouldn't know what it looked like.
I would be happy to get it professionally serviced but there isn't anyone local willing to do it. A new heater would not be very expensive but a big messy job to fit and I would much prefer to get this one working if possible. Sorry, I don't have a model number (if there is one, I can't see it), nor a photo of the burner unit, though I could get one if that would help.
To save me asking another question further down the line: the issue I was expecting to find was that the thermocouple no longer worked. Can anyone recommend a universal one that would be likely to work just in case I can get the gas to light and then the thermocouple does become an issue.
Thank you!
Thank you!
