superheat6k
I am making a sun awning and need to join two standard width pieces to form a central seam.
Can some one give me a tip on how best to neatly join these.
I was thinking of laying the two pieces together along the joint with the outer surfaces together, and with a stagger ~ 20mm, then run a stitch line ~ 12mm from the overlap edge.. Then I would fold over the protruding edge around the shorter edge, then run a further seam along the edge of the overlap, with the cloth opened flat.
Will this work and provide a neat joint ?
