kieronriley
hi ,and good evening, a lad in our club has just bought a johnson 4 hp outboard and it didn't run properly, so he asked me if i would clean his carb as that's what he thought it was. i cleaned the carb(sonic cleaner) and put it back on but it was no better, on further examination i found that the bottom plug wasn't firing so i put a new plug in it and it still didn't fire (but there was a spark now, then on playing a bit more with it i discovered that when it reached almost full revs then the bottom cylinder stared to fire up and it revved really fast, so my thoughts are that there is not enough compression but as the piston speeds up so the compression builds up and it fires, what do you think. I have a compression tester being delivered on Thursday so i hope that will help me with the diagnosis . Any thoughts are really welcome ,thanks. Kieron
