Wansworth
Oh dear.......but the yachting mag journals seemed quite pleased
Well it was a bit of a disaster one of the SS rods used for steering the rudder failed, eventually a new one was sent and we only had time to do a day sail to test it worked. One interesting thing is it has bow and stern thrusters and there is a 'hold' function that holds the boat against the pontoon so a single hander can tie the warps. The mast is 85 feet high and the displacement is 34 tons it also has a lifting keel.
What really surprised us is we were sailing up wind in 20 knots of wind and the boat was heeled so the sea was just about five inches below the toe rail, if you have that you have to hang on with one hand making it almost impossible to get dressed, undressed or cook, the other thing was the seas were only two feet and downwind the boat was rolling, Their site doesn't give keel weight but the above suggests the weight is significantly less than required it needs a much heavier keel or the other option is fit a significantly smaller mast or a mix of both.
To put that into context we had a heavy displacement long keel with cutaway forefoot steel ketch and in 20 knots upwind it would heel 10 degrees it also wouldn't roll in in that tiny sea. The bottom line is even if we had the money we would never buy one.
But some here much prefer new AWBs to MABs that are good seaboats & req loadsa £s continually spent to maintain them![]()
Sounds like she wanted a reef in.What really surprised us is we were sailing up wind in 20 knots of wind and the boat was heeled so the sea was just about five inches below the toe rail, if you have that you have to hang on with one hand making it almost impossible to get dressed, undressed or cook,
I disagree.
Depends what you want out of your sailing but I'd consider 10 degrees heel in 20 knots wind (true?) as rather underpowered
Evidently, you fail to understand what the Gunfleet 58 is primarily built to do.
Interesting! The Gunfleet site gives displacement as 31 tonnes. In comparison an Oyster 575 has a displacement of 27tonnes. Oysters are not known a rolly craft or being too light, so there may be a more fundamental design feature/flaw that makes the Gunfleet heavier heel so easily and so rolly. Of course Gunfleet's owner is Richard Matthews who founded Oyster!The mast is 85 feet high and the displacement is 34 tons it also has a lifting keel.
.................it needs a much heavier keel or the other option is fit a significantly smaller mast or a mix of both.
... and there is a 'hold' function that holds the boat against the pontoon so a single hander can tie the warps.
With what? or are you taking about life in general?
But unless you are prepared to spend a lot of time (and money) on maintenance then long keeled heavy displacement yachts are a thing of the past (or a very expensive bespoke production). So - if you want to actually spend time sailing you need an AWB.
The figure I gave is what the owner told me, having looked it up he is wrong and you are right.
I think the lifting keel, it's too light, a problem that Oysters don't have, Gunfleet is intending to build another version of the 58 with a traditional keel so thay may sort out the severe heeling problem.
Sorry, got diverted. I disagree with :
We have a long keeled (quite) heavy production yacht without bow thrusters that costs no more to maintain than an equivalent AWB. We can go sailing as often as any AWB owner, the constraints are the usual ones around 'life in general' not due to any intrinsic restrictions imposed by having a long keel boat. Hence I disagree with with your assertion that you won't do much sailing unless you have an AWB.
