CFarr
I replaced my old Jabsco pump with a new twist & lock a year or so ago and all has been fine until last season when the lever started flicking back slightly (on the first pump) when pushed over to the right to drain.
it is only a very slight movement, barely noticeable but it does stop you being able to pump. We now have to hold the lever hard over while pumping at the same time and after 2 or 3 pumps it stays where it is and we can release it.
is this something I can sort easily before I buy a complete new pump again?
All is fine on the flush setting when the lever is over to the left.
I’ve removed and reassembled the top gaskets which has made no difference.
I've also removed the joker valve, cleaned and refitted - also no difference.
TIA
TIA
