pcatterall
The dam pump assembly is leaking again !! it seems to be the O ring which is fitted into part 18. On pumping water is forced past the ring and out of the top of the pump. It only leaks when pumping and not when the item is 'locked'.
The O ring is not seperate, it seems to be in a metal retaining cage. I believe that I once took the item to bits to see if I could replace the O ring.
I now have 2 spares packs complete except for part 18 and soon to have a third unless some ( wonderful) forumite can come up with a solution!!
