quaelgeist2
Our 5-year-old Jabsco Par has started to play up a bit recently.
- Pumping in fresh water OK
- Pumping out works well no deterioration of performance visible
- Occasionally the lever at the top appears to fail, blocking the pump out, but can be easily corrected in its position and then pumping works again.
BUT: Within 10-20 min after emptying the bowl, the water level slowly raises about 20cm (to what I guess is outside sea level), to remain like that regardless. Repeated pumping does not help, the water climbs back.
Is there a kind of return valve, does the kind of spare part I need come with one of the typical spare kits? I am asking because looking at the prices of new toilets I want to be sure that it can be fixed easily before a dive into the s**it (no pun intended).
