NormanS
All this fuss is about a temporary set-up for running the engine, while the boat is ashore.
The Jabsco supplies sea water to the heat exchanger and currently it is fed via a filter from a shore supply tank during engine tuning. (The boat is on the hard).
The feed to the pump intake is plastic ring reinforced suction pipe. Despite two Jubilee clips, I cannot stop a weep from this joint. The mechanism of a Jubilee clip is such that there is a discontinuity of bore smoothness. The two clips are spaced 180° apart.
The hose reinforcing spiral may prevent compression.
Do I need a different clip or different hose?
I accept that, in the water, there will be near zero pressure at the intake but, currently, there is about 2 metres of head.
All help please.
Could you not wrap some of the rubber self amalgamating tape round the outlet, that would take up some of the difference in size, then Jubilee clip it on, you could also use a heat gun on the pipe and it may help to shrink the pipe.
