dtfmw
We're very new yacht owners, and are having trouble working out why our Jabsco manual toilet (Model 29090-2000) bowl won't empty. We've installed everything in the service kit (piston O-ring, bottom valve gasket, joker valve) and after this it did empty perfectly a couple of times, but now the water refuses to budge again. The handle is easy to push and pull - in fact when it's moved you can hear water sloshing, although the water in the bowl doesn't move. We've checked the waste tank is empty, and the waste tank vent isn't blocked. What's the next step? How do we investigate whether there is a blockage in the outlet (waste) hose? It's pretty inaccessible on the boat. Any advice would be greatly appreciated.
