lumphammer
As the title - is there a way to slow down flow rate? Maybe some sort of choke valve in outlet, or using less powerful pump e.g. Jabsco 1.9?
Probably better to restrict the output rather than the input. If the latter, you would starve the supply and maybe damage the rotor.
What's it used for?
That's the pump I have and that's how it works. Turn the tap on just a bit and you get a dribble. Full on it scoots out.Why would you want to throttle the flow rate? The tap does that, just don't turn it on full.
Perhaps replacing the tap with one that is more controllable would be a cheaper option that changing the pump!
I can only think the OP is blowing off his pipe connectors at 2.9 which didn't happen at 1.9 maybe ? Maybe he's fed up with washing out his bilges with nice hot water from the calorifier ?
Thanks for that pvb why would anyone buy the 1.9 then? We replaced ours with the 2.9 on last boat but I just wondered based on your advice.
yes it does - but with the tap fully open water splashes everywhere and it would be nice not to have to remind anyone who doesn't want an impromptu shower not to turn the tap full on,
