I've a cunning plan
Brian_B
7 Jul 2003
Plymouth
I\'ve a cunning plan
I'm thinking of using my spinnaker pole as a bowsprit to fly a cruising chute to move it forward of the pulpit. It should be possible with a deck fitting and attachment to the bow roller.
What do you think of the idea? Have any of you already tried this?
Re: I\'ve a cunning plan
The Dehler 37 Cruising uses a simalar system. There is an attachment point on the deck, and a 'hoop' welded into the pulpit for the pole to pass through. Its meant to work well ... would be interesting to hear from anyone who's used it?
I'd be wary about putting a kink in the spinny pole - be careful about how far you push it out and load it up... the pole is designed to work in compression.
S'not a new plan, I'm afraid.
The IAC yachts have done this for years as they were prohibited from carrying a bowsprit - but on a regualr yacht suspect you'd need to extend the pole track further down the mast and obviously enure the bow fitting was stronger than say your pulpit.
Cheers
JOHN
How about a bobstay?
The spinny pole would only be under compression then.
As suggested it all depends on how far out the pole is working unsupported. A couple of feet should be no problem in gentle conditions. Beyond that you should consider staying the pole end both sideways and downwards. A dedicated short pole or similar fitting might be more tidy. olewill
I have this system on my Dehler 35CWS. As the rig is 7/8th, it works well with masthead cruising chute, by getting the sail further forward of the forestay. I belive its standard kit on the 35 & 37 (not sure about the others).
Don't do it - my pole is now in two pieces after having exactly the same cunning plan. Light (ish) wind and only a couple of feet protruding unsupported!
And yes, it is embarrassing when it goes wrong!
Why not just get a nice lump of pine from your local builder's merchant. No knots & nice & straight, Then get stuck in with a plane/ spoke shave to round it off & taper the ends. It will look a treat with a bit of varnish & a couple of suitable end fittings. Excellent winter project & you have a spare spinnaker pole or can goosewing Genoa & Cruising chute.
