Russ the Diver
Just thought I'd add, I'm a domestic appliance engineer if you need my help!
I award this post Comedy Platinum, funniest thing I have read for ages.Discovered that our new all singing and dancing Samsung machine has a 'bubble soak' setting. This does a great job cleaning them most disgusting green laden mooring lines. Tied an old towel around the shackles with cable ties and went for it.
Discovered that the cycle was nearly 3 hours, evaded capture only to be given away by leaving the now pristine lines hanging up in the garage. The ensuing debate about why I had bought new lines when we were on an economy drive I has instigated. That was because of the vast cost of our new washing machine.
This left me with facing Bart's [as in The Simpsons] dilemma.
That is I am damned if I say I used the washing machine and I'm damned if I say I bought new lines.
Fessed up and now the 'bubble soak' programme is the solution to all our problems - well most anyway.
Arnt American washing machines centre ( or is it center ) oscillating paddle things rather that our type of drum machinesPillow cases. If they are bad, soak first.
I did an article on washing ropes in cooperation with New England Ropes (they supplied the rope and did the before/after breaking).
a. Without pillowcases ropes can wrap around the center and break the transmission.
b. Bits can get around the water pump seal and choke it.
c. Some like fabric softener, but if you want to do it right, use Nix Wax Polar Proof. Gives lasting softness and reduces water weight gain. Forget the instructions and just soak them in 5-gallon buckets after washing and drying. Goes farther than they say.
I learned as much about washer repair as I did about ropes.
Yes - on the basis of the eternal promise that I will replace it if I break it. As I will replace it anyway even if someone else were to break it, its equal odds, but I suppose it gives them something (else) to moan at us about, eh !
Had a similar conversation about using the iron yesterday for applying my new veneer !
I have no problem with washing lines in the domestic washing machine. One of SWMBO's maintenance tasks is washing the lines! In the washing machine if available. Also responsible for Blakes Valves and winches, neither of which requires a washing machine.
Hasn't left me yet, now in South Africa from Portsmouth UK.
