havin purchased an aging westerly 30, completely refurbished inside, looking very good I must say, launch day came so did the crane, 16 ton hi- ab remote controlled, did a fantastic job dropped boat onto beach, waited for tide, started engine and motored onto mooring. Being extremely keen to take her for her first sail in a long time, up with main and no1. To the shouts of joy at making 6 knots in a light wind enjoying the odd "Stella" shouts from below from my 9 year old daughter!! dad can I use the loo, "of course you can sweatheart" after using it myself along with various crew members the time came to reduce sail and head back to the mooring, first night on board excitment grew, cosy inside and outside the wind going to the north and blowing at around 30 knots, after only having had cats previously needless to say it was a bit bumpy, but we survived and headed in to the shelter of our winter mooring that afternoon. With no wind a flat sea and being able to step ashore it was a haven. The time was then spent trying to fathom out why the loo wont pump or empty, some of you will state the obvious"are the cocks open , one definately is the other the outlet is either permannently siezed open or shut I dont know, either way I am stuck with a loittle puddle in the loo, I believe that it is a sl400 and an old one at that, so sensible suggestions please. Last but not least all of the deck fittings and winches are original(Bakelite) I mean tufnol or imitation brown stuff!! I have two barlow winches that I would like to put on, can I assume that the hole centres forn the fixing bolts are the same? Last but not least, those of you that have or are about to have a boat transported pump the bilges first!!, I was renewing the impeller on the MD2 and noticed some old water and oil in the bilge, not realising that the bilge on the westerly 30 was so deep ignored it, of course when a HI-AB travells at near 70mph stops and starts en route, where does the water and oil go? into every nook and cranny it can find covering the recently varnished floors and sails stowed in the wrong lockers. Just thought you might enjoy my little experience, once bitten twice shy so they say>
