Is this Propeller Servicable?
Tim Good
26 Feb 2010
Bristol
As you can see I spotted some stress fractures on the prop the other day... is this type of this fixable or am I best just getting a new one? It's a Beneteau First 26 and on a Yanmar 1GM10. you can also see some fairly big chunks out of each blade on the 2nd photo.
johnlilley
30 May 2001
South Dorset/moored Poole/lay up Wareham
www.seasurveys.co.uk
Looks more like dezincification (corrosion) on the tips. Can you break bits off or does the tip of the blade bend if using pliers (little bits only for testing). Corroded tip bits on blades simply break off like dry corn flakes & leave a dull coppery colour edge.Sound bronze will bend.
If dezincified then replace. If not then it can be possible to bronze weld the fracture, but the fracture area also looks suspect with regard to corrosion as well. Does the blade "ring" when tapped with hammer. Corroded blades just have a dull dead noise with hardly any ring.
Ultimately best advice would be to replace as there is too much that needs repair.
John Lilley
sailorman
21 May 2003
Here or thertemp ashore
NO
would suggest you also move the anode much closer to the P bracket, that anode is not doing much at all by the appearance of it
david_bagshaw
5 Jun 2001
uk
Just think what damage that cracked blade might do to the hull if it flew off while going hard astern.
Then ask which is cheaper, repairing the hull damage, and the object you might hit , along with the damage to the p bracket while the one blade prop whirls around.
The chunks out could be repaired, but the crack is at the root, It would be difficult to repair to the base of the crack shown.
Replace, Replace Replace
Tim Good
26 Feb 2010
Bristol
It had it, time for a replacement. However, plenty second hand props around and cheaper than repairing your old one.
I'm not very experience in prop design nor the correct size or type for a given boat / engine. Any guidance on what I'm looking for? 2 blade or 3? Specific feather angle? Best place for 2nd hand ones?
sailorman
21 May 2003
the prop dims should be on the aft face of the prop boss or on the boss between the blades
eg - 15 x 10
15 dia
10 pitch
Tranona
10 Nov 2007
As sailorman says, the size will be marked on the boss of the prop. If it is not then give your boat/engine/gearbox details to the supplier and they will work out the correct size for you. A simple 2 blade prop just like the one you have will be fine. Extra drag of 3 blade not worth it. You can get props mail order from Sillette Sonic or T Norris.
Bit concerned about the level of dezincification as the anode on the prop does not seem to have eroded. What was the old shaft anode like?
Bilgediver
6 Jun 2001
Scotland
The most serious matter is what looks quite a long crack across the base of one blade. One bladed props run slightly unbalanced :cool::)
Definitely one for a scrappy!
Colvic Watson
23 Nov 2004
Norfolk
With that type of performance small cruiser I'd get a feathering Kiwi prop - and no problems with the blade corroding. About £800.
robmcg
17 Sep 2006
In exile in Scotland
You could try Woods of Crediton, they seem to have piles of props there. You will need to know the size, pitch and taper though.
Tranona
10 Nov 2007
However, requires a minimum of 20hp to make it work, and the OP only has 9hp from his engine. Nothing wrong with that 2 blade fixed prop for under £300! If he wants drag reduction under sail then a basic 2 blade folder would be the logical choice.
Colvic Watson
23 Nov 2004
Norfolk
Ooops sorry you're right.
Norman_E
15 Mar 2005
East Sussex.
................Bit concerned about the level of dezincification as the anode on the prop does not seem to have eroded. What was the old shaft anode like?
There is no anode on the prop. There should be one that fits onto the nut, which is what you can see, held in place with an Allen screw into the threaded hole in the end of the nut. This sort, sometimes called a Beneteau type. http://www.mailspeedmarine.com/anodes/plastimo/conical-shaft-nut-anodes-1280-128317.bhtml
Tim Good
26 Feb 2010
Bristol
Urrr really? Another that goes on the end other than the shaft anode?
Could be why i have so much play in the P Bracket which could be loose because of dezincification. Different issue that needs sorting.
