TNLI
TBN= Total Base Number.
A measure of how much acid the oil can absorb without becoming acidic
May be controlled by additives other than detergents.
My memory of BMC engines is that they tended to wear out a lot quicker than modern ones?
My parents used to have BMC cars where the engines ahad often been replaced or rebuilt before 70k miles.
And in those days engines were considered OK when they'd fail a modern emissions test by a very big margin.
Some of the BMC engines are not that great in block wear rates. The only one that is really bomb proof is the one used for the RNLI Rother 37 offshore boats. The BMC 1500 !! That engine was marinised by a whole bunch of companies with a lot of different options like keel cooling and remote hydraulics boxes.
Alas the name plates seem to fall off the rocker covers and gearboxes. So I have no idea who marinised mine and it's taken quite a while to ID the hydraulic box, (It uses engine oil), as a TMP 100. The Thornycroft 1.5 version, (standard BMC 1500 block), is regarded as the best version, but rather rare.
You can fit a modern exhaust system if you are a go green type or don't like fumes when the exhaust pipe or stack is upwind of your berths air intake. One version common in Canada has a bubble ring tube, which is not difficult to make if you like drilling lots of holes in an external stainless pipe.
