Is this anode too big?
Rhylsailer99
19 Jun 2020
I bought a 5kg anode a few years back and thought it was tol big so I fitted a 2kg one. The old 2kg anode now needs replacing and I am thinking is 5kg too heavy for a 28ft boat. I atill have the 5kg anode available and not sure if I should buy another 2kg and sell the 5kg one or just fit the 5kg anode.
Seastoke
20 Sep 2011
It will last 2 years. Make sure the bolts are good and check cables on the inside bilge.
Tranona
10 Nov 2007
Yes. Twice as big as you need. This is what is normally fitted marinesuperstore.com/anodes/zinc-hull-anodes/z-guard-zinc-pear-shaped-hull-anode-2-1kg-zg77kit?utm_source=google_shopping&utm_medium=pcn&utm_campaign=MSS&utm_term=ZG77KIT&gad_source=1&gclid=CjwKCAjw-JG5BhBZEiwAt7JR65rySGNCHLTL25AUMBSU3Bizgb_hJbVWwEcpRiwmXkFu3yVOWeKmiBoCsq0QAvD_BwE
Same centres. You would be in real trouble if you had galvanic problems serious enough to justify a 4kg anode. The normal 2kg often lasts several years on a simple sailing boat protecting the propeller.
Rhylsailer99
19 Jun 2020
That is what I fitted last time and lasted over a couple of years.
Tranona
10 Nov 2007
In theory the bigger one will last twice as long and might be worth it if you intend keeping the boat afloat for several years. Have a look around and you will rarely se a large anode on a small sailing boat.
Tranona
10 Nov 2007
The centres are the same for both sizes (200mm), but the smaller pear shaped one has part of the strap exposed whereas the strap on the larger one is fully cast in. So they are physically interchangeable.
Neeves
20 Nov 2011
Sydney, Australia.
If you notice the extra weight and/or the increased drag - you are a VERY sensitive owner (sensitive in terms of sailing performance). As such you should be sailing (sorry, racing) a lightweight, twitchy and fast performance sailing yacht. If this is not you just fit the big anode (especially as it fits) as you will inevitably make a loss if you try to trade it in.
Hopefully it will lose the same weight per annum as the 2kg version and you can tell us the wear rate in 6 years time :) - I'll try to remember to add it it to my calendar so that I can post a reminder for you :)
Jonathan
Tranona
10 Nov 2007
What's this anode bonded to / protecting? Assuming your boat is GRP, there's a good chance it's not needed. A shaft anode will look after your prop, and your through hulls will be fine provided they are DZR, bronze, or plastic.
There is no exposed shaft on his boat. A hull anode is usual and it is needed - he says it lasts a couple of years. An anode has no effect on through hulls even if they are plain 60/40 brass as they ar on most modern boats when new.
Tranona
10 Nov 2007
As the boat is a bilge keel would it be correct to assume that the keels are metal?
No - some boats have encapsulated ballast inside GRP mouldings. would not make any difference to anodes as they are not effective generally in preventing corrosion of metal keels. The only effective way of preventing corrosion on keels is to exclude water. A good coating system such as epoxy applied on a properly prepared surface can work.
wingcommander
25 Jul 2013
Similar case on my Vancouver 27. No shaft anode, so big hull anode showing signs of wear.Small rudder anode . However all my through hulls ( bronze ) are internally bonded . I have attempted to delve deeper and only find conflicting information . So I have left as found . Do you have a layman's reasoning for your statement.
