Eren
I have MAN diagnostic screens that give me loads of instant technical info about the engines while on the run. One of the data that they provide is “Air pressure after filter”. So it measures the pressure at the space between the filter and the turbo. It used to be 0 or -1 bar, whereas the last time it showed -2 bars (on both engines). With simple thinking, I understand this as the filter is getting clogged and it is getting harder for the engines to breath. At the same screens, there are 3 lights on the right side of each parameter, green, yellow and red. As all may guess, green says “all is OK”, yellow says “not so much” and eventually red is alarm.
In all my boats it has been a question for me to guess when to replace the filters. Do you think that this “air pressure after filter” parameter is good for deciding for replacement of filters?
