VicMallows
Well I noticed that the bottom edge of my lowest washboard is made of solid hardwood whereas the rest of them is plywood so Sadlers must have had some reservations.
Obviously some cost-cutting in later years
Slight thread drift but what would you use to build the carcasses for the galley. I think carpenter was talking about Robbins Elite which i thought was OTT?
I'd heard a variety of things regarding mystical Marine ply.
1. all ply glue is waterproof
2 the guarantee of voids is the difference
3 Marine ply is made of hardwood.
No idea if any one of the above are actually true, but it's what people have told me at various times in the past.
WBP Glue Line -- BS 1088 plywood must use an adhesive, which has been proven to be highly resistant to weather, micro-organisms, cold and boiling water, steam and dry heat. The product's bonding must pass a series of British Standard tests.
Face Veneers -- These must present a solid surface that is free from open defects. Face veneers must be free of knots other than "sound pin" knots, of which there shall be no more than six(6) in any area of one(1) square foot, and there can be no more than an Average of two(2) such knots per square foot area over the entire surface of the plywood sheet. The veneers must be reasonably free from irregular grain. The use of edge joints is limited, and end joints are not allowed.
Core Veneers -- Core veneers have the same basic requirements as face veneers, except that small splits are allowed, and there is no limit on the number of pin knots or edge joints. However, end joints are not permitted.
Limits of Manufacturing Defects -- Defective bonds, pleats and overlaps, and gaps in faces are not permitted. Occasional gaps may be repaired using veneer inserts bonded with the proper adhesive.
Moisture Content -- BS 1088 plywood must have a moisture content between 6% and 14% when it leaves the factory.
Finishing -- Boards will be sanded on both sides equally.
