Is it wider????
Lakesailor
15 Feb 2005
Near Here
Another little job for the techies. Limit the number of characters in a subject heading. It would have been handy if Explorers had edited the subject once his picture problem had been sorted. Perhaps one the regulars could have suggested it.
bigwow
26 Feb 2006
After No1 son plugged in this new monitor the whole index page only cover half the screen, it ends under the “search YBW tab, although the header goes right across.
Anyone know how I fix it?
grumpy_o_g
9 Jan 2005
South Coast
Right-click on the desktop then Properties-Settings and try changing the Screen Resolution. Depending on your particular set-up there may be something in the Advanced section (button at bottom right on the same box) that affects it as well. If that doesn't work make sure the driver your using is the right on for the display.
Watch out experimnenting too much or you could end up not being able to see the screen to back out what you just did.
Geoff
bigwow
26 Feb 2006
Did as you said, had a look, then thought I'd better leave it untill my son visits again or I could be left with a blank screen!
Thanks anyway.
John
