Is it possible ? and who could do it ?
Sixpence
24 Aug 2005
Here, yah fule
If you knew the exact location of something floating in the middle of an ocean as big as the Atlantic , at a particular date and time , and you knew its size and most other details about it , is there a way of working out where this object would most likely be after a set period of time , taking into account things like known weather conditions and current flow
BrendanS
11 Jun 2002
Tesla in Space
Yes, if you have the data available. Most oceanographic organisations could map it if you had a good enough reason to request the computer power required.
On a smaller scale, coastguards will do this for call outs in uk, as part of finding missing craft etc.
You can even do it yourself, as we used to do on night exercises in our club. Let loose a buoy at a set time in the dark, then go find it an hour later. Having done the calculations before hand.
Sixpence
24 Aug 2005
Here, yah fule
ah , but could it be done in the middle of a body of water as big as the Atlantic or Pacific where tides don't really affect things , only currents and the weather , and say , up to a month later than it was put there , but still without using megga computer power or expense
Cruiser2B
3 Nov 2005
Canada
In essence you're talking about running an EP for a month. And without actual observations of wind and sea, you'll be relying on calculated data. I think even the supercomputer would give you an ocean-sized PPA after a month. You could pitch two messages in bottles off the same pier - they might wash up on the same beach, or half a world apart. Nature's just not that reliable.
why did I bother, when all our posts were mutually deleted for a reason I don't understand? It was a lot of time wasted on research?
Wow - that sounds familiar ....
cliffordpope
28 Oct 2005
Pembrokeshire
It would surely basically depend on what the "something floating" was? An iceberg would be influenced almost entirely by current, a piece of foam polystyrene entirely by wind.
It sounds very sinister. Are you worried about where the evidence of some misdeed will come ashore? Perhaps you should have attached the block of concrete more securely.
FullCircle
19 Nov 2003
You would have to know the behaviour of the item in the water to wind and tide and wave height, wave motion.
Depends how accurate you want to be. If you want to be accurate, fit an Globaltrack style transponder and a one month capacity battery. Then follow it on Google Earth.
FullCircle
19 Nov 2003
You can view things moving there almost in real time, although realistically 20 minutes. Globaltrack gives you speed and direction too.
Webcraft also is plotted on Google Earth.....
phanakapan
26 Mar 2002
Cruising
Duncan, I think Trevera25 is trying to get info that might help to find S/Y Colros (see salvaging Colros thread) so unfortunately your remark might appear flippant- inadvertantly I'm sure.
cliffordpope
28 Oct 2005
Pembrokeshire
I'm sorry, I started that frivolous line of thought. Obviously I had no inkling of any particular motive behind the OP's enquiry - none was specified, it appeared to be entirely hypothetical, and as such inspired my macabre instinct that something was afoot.
But presumably in a real case of searching for survivors etc, all possible means and expertise are automatically directed to the problem, making full use of data on wind and current drift?
