starz
What is the best method of protecting cast aluminum from corrosion when it will be attached to stainless steel and dumped into sea water where it would reside for 10 years without any access to it?
Ok, what i am talking about is not part of a boat, but rather a washing machine.
I'm posting here because folks at the washer forums haven't come up with a solution yet. I've seen a few posts here talking about similar problems so i figured you guys might have some experience dealing with these materials in such environments.
The aluminum part is called a spider-arm. It's attached to a stainless steel drum. The drum is of course where you put your clothes. This setup is (afaik) always on a front load washer. The thing is, the spider always corrodes and breaks - mine did in just 3 years. It's inevitable. Lots of theories as to why that happens...galvanic corrosion, water PH levels, too little detergent, too much detergent, using cold water, keeping the washer door closed...and so on.
Those who say its NOT galvanic corrosion argue that if it was, the spider would have corroded at the points where it meets the stainless steel drum (the 3 ends), and at the shaft. Although most of the corroded spiders i've seen corrode a few inches from the shaft, i'm yet to see most of the corrosion happening at the spider-arm end joints...or immediately at the shaft. So they are of the opinion that the reason it is corroding is because of soap and high PH water.
In any case, i am getting ready to put in a new spider-arm and i would like to treat/coat it (and/or the stainless steel directly under it) so that i could get at least 10 years out of it.
I am thinking of first etching it with phosphoric acid, then anodizing it, and finally spraying it with a 2 part epoxy primer. What do you guys think?
