mph
Does anyone know how to check bilge water to see if it’s sea water or freshwater? The obvious has been tried e.g taste it…and it doesn’t taste of anything much..
A chum has found more bilge water than expected in the bottom of his boat, he’ll be leaving the boat un-attended for a month or so soon and wants to know a sure way to trace the likely source.
The boat is a Beneteau 411. The stern gland is a Volvo dripless seal and OK when last checked. The freshwater system could be the source – there is just one pressure pump midships and two long pipe runs from the bow & stern tanks. Any leak in the fresh water system must be on the ‘tank’ side of the pump as it doesn’t keep cycling on and off.
So, does anyone know a way to test if the low pressure system is leaking? Pressure maybe?
