jimi
Any tips on places to stop, I draw 2m, I'm thinking the best options are Blyth, Eyemouth and Peterhead.
And Whitby if you want a break before Blyth, either in the outer harbour or through the lift bridge into the marina. Not a good entrance in a strong onshore wind though.
We're berthed in the Royal Quays marina a couple of miles up the Tyne from the sea, and are members of the Northumberland Yacht Club on the river Blyth. Both offer easy access from the sea in most conditions. They’re less than 10 miles apart so passing boats would usually pick one or the other.
The next marina up the coast from here is Amble, which is deep water held behind a sill 1.8m above chart datum.
Further up, the anchorages at Newton, the Farne Islands and Lindifarne are tenable if the weather is placid.
The currents can be strong around the Farnes and worth timing the passage; and avoiding strong wind against tide, otherwise the inshore route is simple enough.
Take a few days here to enjoy the trip.
Berwick is usually avoided because of the shifting shallow sand banks.
Eyemouth has a narrow entrance with rocks to avoid outside so I’d avoid it if the wind has had any east or north in it to stir the swell. Also, the stated depth is shallower than the actual depth; the harbour master can advise. The alongside pontoons are in shallow water which reputedly is over soft mud. If you don’t want to risk it then the deeper water that they mention is in the Gunsgreen basin – a somewhat unappealing place with concrete quays and fishing boats moving around at all hours.
Port Edgar by Edinburgh is accessible but this is well out of the way of your route.
The next non-drying harbour is Abroath before you head further north.
