IPS IPS....Where Art Thou IPS ?
8%, according to Seatorque.
http://seatorque.com/boss.asp
"Reduced turbulence through the propeller due to the non rotating shaft casing, plus eliminating cutlass bearings and stuffing boxes allows for an average* of 8% extra delivered Horse Power to the propeller.
Calculate the cost of upgrading to the next size engine in Horse Power terms, and the BOSSTM makes sound economical sense."
Thats an interesting concept - the shaft enclosures could be antifouled as well and save on both economy and maybe some maintenance costs.
if the shafts could be enclosed and still use rubber cutlass bearings then maintenance issues would be simple. It would need to either use the raw water from the engine to run down the inside of the tube and through the cutlass bearing or have some clever shaped end to permit water through cutlass as the boats moves along.
All true!
I met with ZF planning guys back in September. Initially we discussed the impact of dissolution of Cummins Mercuiser Diesel and walked away enlightened.
IPS and Zeus take up has stalled, higher service costs than shaft drives and bow/stern thruster integration packages about to be launched, Mercruiser pulling the rug under Cummins on Zeus exclusivity leading to Cat and Yanmar offering system therefore no takers. Crummy Volvo DPH saga goes on, ZF not sitting on their hands, they can sense blood.
Over the next three years ZF set to offer outdrives up to 450 hp and totally new range of pod drives which will change the market place.
Just file this posting and wait........
I go back to my earlier contribution a hull needs to be optimised to the type of drive.
You cant have a single hull that can be fitted with shafts, outdrives or waterjets and be fully efficient and optimised, it will be a severe compromise for two of the three.
Each form of drives has its advantages and disadvantages.
I have only driven two IPS boats and its manoevrability was awesome, I have twin shaft plus bow and sternthruster and that is pretty good but lots of levers, I reckon even my wife could drive an ips with joystick after half an hours training, ( i would not let her berth my current boat in a tight spot).
When I worked with Hydrofoils our boats all had a p bracket and a cutlass bearing on the after foils, some italian boats had the same shaft arangement but the shaft terminates in a cutlass bearing on the after foil but the prop was ahead of the foil and therefore running in cleaner water, so less cavitation from disturbed water.
IPS is good in as far as the props run in clean water no shafts and p brackets to disturb the water ahead of the prop and the prop is providing thrust paralell to the boat line rather than pointing at angle downwards as shaft boats where say 15% of the thrust is not in the direction of travel but lost downwards.
Outdrive is good in as far as thrust again is forwads and not 15% downwards as shaft but props running in disturbed water.
I was involved in running water jet ferries and they are great and very reliable in constant use but the hull design , vessel weight and lcg are esseintial that they are correct to perform well , you also get lift from where the water intake is just in the same way that a foil running in water or an aircraft wing does, the position relative to the waterline for the jet outlet is also essential.
Horses for courses as they say, depends on the application, depends on the budget and each has advantages and disadvantages.
I have seen few problems with waterjets, lots with outdrives but serious fuel savings, and few problems with IPS but complicated and expensive without a large fuel advantage partially in my mind as I dont belive the IPS design and the boat design are optimised Ie a boat designed purely for IPS as drive.
