Seastoke
So we have a generator a battery bank and inverter , so how do you use you set up , we tend to use the inverter over night to ie charge phones etc , but we lose the 240v at some time . Does this knacker the batterie .
IMO, that strategy only works for a couple of days.We have 500ah house batteries , 4kva generator and 500w victron inverter that is on permanently to run both TVs and assorted charging plugs, it also runs a small freezer when shore power is off. At anchor in a 24 hour period we will run the generator for 2-3 hours morning and evening , with water heating / kettle on and that seems to work for us.
Hurricane assumes standard lead acid batteries are used. Nowadays there are alternatives such as lead carbon and lithium, which can go much lower than 50% DOD with no ill effects and recharge much quicker due to less internal resistance. Time to charge also depends on the charger of course, but more importantly the charger/battery type pairing.IMO, that strategy only works for a couple of days.
2 to 3 hours charge doesn't completely charge the batteries.
As a result, the charged state of the batteries gets lower and lower.
Remember that you only have 50% usable charge in your battery bank so after a few days you can easily reach that level.
Hit 50% and thats the bank knackered.
I use your strategy but I have solar panels that finish off the charging.
Batteries take most current when they are empty and to save running the generator until they a completely charged, my solar panels will finish the job.
The panels aren't big enough to completely charge the batteries.
Yep agreed Hurricane, have always regarded your set up pretty much as good as you can get. To be fair we only manage 2-3 days tops on the hook so I'm comfortable with what we do, but i have been browsing a few solar panels in case we start spending longer away.IMO, that strategy only works for a couple of days.
Agreed but how many people have Lithiums - they are still way more expensive than lead acid.Hurricane assumes standard lead acid batteries are used. Nowadays there are alternatives such as lead carbon and lithium, which can go much lower than 50% DOD with no ill effects and recharge much quicker due to less internal resistance. Time to charge also depends on the charger of course, but more importantly the charger/battery type pairing.
I’ve had solar panels for over 10 years. Now 250W. I almost never use the 240v battery charger, maybe just a few hours each year. The panels keep the batteries nicely topped up. And when on a trot mooring on the Dart I also used to leave my large fridge freezer permanently on, the panels coped well with that too.Yep agreed Hurricane, have always regarded your set up pretty much as good as you can get. To be fair we only manage 2-3 days tops on the hook so I'm comfortable with what we do, but i have been browsing a few solar panels in case we start spending longer away.
Agree. You don’t need 240V to charge a phone. I had 12V USB sockets installed in the cabins on my boat and they are perfectly adequate for charging phones overnightAs an alternative you could consider 12v usb sockets for charging.
Draw is minimal on phones etc.
We didn’t buy it to sit in a marina.
Please show us where?the initial sticker shock can be a bit off putting but they are dropping in price a lot and you can get the equivalent lithium for not much more than a good AGM battery and you don't need a noisy generator
BMS? Relays, fuses, compatibility with chargers, etc? Have you read the PBO lifepo4 thread?
Things are not that simple...
