nfluester
Duplicate
I vaguely remember your video contributions to the thread, hence asking as I was expecting you'd advocate the kit building approach.Yes obviously these are "drop in" type so have the BMS and low voltage / high voltage cut off internally probably worth an alternator protection device to protect against high voltage disconnect and a dc to dc for alternator but so long as your shore charger and charging sources support ~14.4v constant voltage charge profile then for basic use you can be up and running
Yes I have read the PBO thread and inputted to it, there my lifepo4 system have a REC ABMS can bus BMS and can bus Wakespeed alternator regulators all talking to the victron inverter and charger but that's not for everyone
Further, such drop ins are going to be useless on a 24V heavy loaded with kit 67ft (iirc) mobo that Mike has.
in general Lithium batteries have a very low internal resistance which means they can give out loads of power potentially even up to 100% of their capacity and can accept loads of amps in charge to charge back up quickly. Lithium batteries also generally have a ridiculously large amount of cycle life generally >3000 cycles
the discharge curve of lithium batteries is very flat for most of the discharge which means they provide a very constant voltage under load which is great for continuous power draw unlike the large voltage drop under load experienced with lead acid
no offence, but imho these ready made kits are going to give lifepo4 a bad name down the road and are again imho for NO ONE!
There are some nuisances so can vary manufacturer to manufacturer but generally parallel is OK.can you join these "drop-ins" in parallel? Would the BMS etc work with cell balancing?
Yes they will.100AhX2 for 24V, to do what? I guess needs something beefier and something that you can suck more amps out of in use.
FE, running a watermaker off my batteries demands circa 85A@24V. iirc the bms on the built all in kits wont allow that rate of discharge
drop ins with Daly BMS?Yes they will.
This is mine at 12v powering the kettle at night so no input from solar. If you need 24v just put a couple in series. The Sterlings can be linked in series to 48v if you want.
From Sterling with a 5 year warranty so no gambling with Ali-Express and risk receiving seconds or B grade cells.
Lithium Batteries
I think that's one of the problems of drop-ins and their BMS limitations.
Mind 50A doesn't sound bad, not sure how many stock alternators will pump safely more than that...
More concerned on discharge abilities for running heavy loads (watermakers, heating elements, etc)
mine also has two 60A alternators (ok at 24V)
first your service bank will only take charge from one of the two, so unless I'm mistaken, forget the 120A,
second, I think you will be running at decent planning speed to get that output. If you remove the engine and other paraphernalia consumption, I think the 50A is OKish. But yes, in theory you should be able to dump much more Amps to them
interesting, I've read about this Fairline approach to one engine starter running off the house bank, and iirc the shore charger NOT charging the other starter only battery...
Are you sure though that you can have current from both alternators going straight to house bank concurrently? or you can only switch one or the other?
