yankeebloke
Following on from my pervious thread, i read a guide or two on installation and they say put the inverter as close to battery as possible, and run the longer wiring on the AC side which makes sense.
But then i get confused.......it mentions a good location close to battery in the engine compartment, but surely the engine compartment gets hot and this is bad for the inverter?
Also as my compartment is below decks, i would not be able to see the inverter and i thought it should be where you can see the warning lights etc?
Where is your inverter?
Will it be ok in the engine compartment? i worry about petrol fumes and sparks etc when inverter kicks in?
all advice will be most welcome...i dont want to cock this up!
BTW it is a 300 watt inverter, going to run a TV that draws 70 watts
i await guidance!
i await guidance!
